Big Question
what would make 88 cbr 600 not light up or anything turn on key nothing good battery no blown fuses good main fuse all wires are in tack what else could this possibly be? please help
could be bad ignition switch or bad main fuse did you check all of the fuses or just the ones in the box make sure your battery cables are tight and battery is fully charged
could it be a bad cdi
it was working fine then when i was cranking it yesterday i hear a pop and everything dies but all fuses are fine could it be the cdi
maybe but it sounds like you lost all power
is the cdi a brain or is just for getting fire only
i think its fire only
