Big Problem
Old 05-10-2010, 07:01 PM
JWoods_F4i's Avatar
Default Big Problem
Ok it all started when i took my bike out thursday, when i would grab the clutch when come coming to a red light the rpms got real low and would cut off if i didnt twist on the throttle. At 1 red light it cut off before i could give it any gas and it would not start. It acted like it wanted to turnover but wouldnt. Its not the battery i had just put a new 1 in it not even 2 weeks before. Now when I try to crank it, it acts like it wants to but it wont turn over then will come a knock sound and after this happens and I try to cranck it again it makes a whinnin sound. does any 1 have any ideas???
Old 05-10-2010, 08:39 PM
jonld's Avatar
check the battery with a voltage meter first. Saying its not the battery because you installed a new one prior too doesnt mean your electrical system is working properly and the battery didnt drain. also when you turn the key on does the fuel pump prime?
Old 05-10-2010, 09:02 PM
JWoods_F4i's Avatar
yes the fuel pump primes. and i took tha battery out the bike and charged it and it still didnt turn over the day after it cut off. I kno i need to take the bike to a shop and have it looked at in detail
Old 05-10-2010, 10:54 PM
redzintimidator's Avatar
check your starter relay and the relay fuse..it is NOT IN THE FUSE BOX! its kind of hidden on the side of the relay, located next to your battery right in front of the fuse box.
Does it click at all when you press the start button?
Old 05-10-2010, 11:56 PM
F4ith's Avatar
It may be a hose is pinched. I had a similar problem with my F2 and I brought it to a dealership and if I remember correctly, they told me a vent hose was clogged or something along that line. Then again, it wasn't fuel injected...
Old 05-11-2010, 01:15 PM
MADMAXF4I's Avatar
Registered Users
when your tried to turn it over duz your lights dim?
Old 05-11-2010, 09:39 PM
JWoods_F4i's Avatar
na they dont dim. they are the regular brightness
Old 05-16-2010, 06:20 PM
JWoods_F4i's Avatar
Ok so i did some work on my bike and got it to start. I played with the starter relay as some1 suggested. The fuse was not blown however the 2 terminal wires that lead to the relay dont seem to make full contact with the bike. I have to push down on the wires for the bike to start properly.
Even though i fixed this problem the bike still will cut off on me if I do not continue to give it throttle. So if I let go of the throttle the RPMS drop and the bike just cuts off. I have no idea why this happens or how it started, and was wondering if anybody had any theroies about this situation?
PS after I got done tryin to keep it cranked by playing with the idleing screw my exausht was literally smoking when i turned the bike off for the last time. I was just wondering if this was normal for yoshi pipes?
kwood
08-08-2012 11:01 AM
hatchtegman
09-01-2010 03:15 PM
vietladin
12-25-2007 09:48 AM
dewthedoo05
09-04-2007 09:32 PM
Trips
11-26-2006 01:45 AM
Quick Reply: Big Problem
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
