Best way to sand/polish out F4I wheels?
Been trying to search the forum to see what the best route is to strip and sand the wheels down to a mirror finish and was wondering if anybody has a tutorial with pictures or from another forum? How much time should it take to just do the wheel lips? Thanks!
The wheel lips are essentially pre-shined. Just use some Kleen Strip around the edges and it should come off with a garden hose.
Past the lip, where the texture roughs up, the paint adheres much more strongly. I think you'll need some sort of wire wheel or something to get all the paint out, or else a ton of sandpaper and patience. Multiple coats of paint stripper didn't take everything off. Here's a pic I took this week when I was stripping my wheels. The really bubbly part is the easy part. https://cbrforum.com/forum/attachmen...t-imag0149-jpg |
might do this to my spare wheel set
why not get them sand blasted?
Try Aircraft Remover.
Thanks does anybody know where a tutorial is on stripping and polishing out wheels.
Try jasco it will work for sure go to home depot and ask for it
Anybody have a tutorial with pics?
You need a picture tutorial for taking sandpaper to your wheels?
1) Spray with aircraft remover 2) Let Sit 3) Pressure Wash to blast away loose paint Repeat steps 1-3 as needed to remove all paint. Then follow this: http://www.honda-tech.com/showthread.php?t=1259115 |
i agree aircraft stripper is the way to go and u can pick it up at most part stores
| All times are GMT -5. The time now is 03:43 AM. |
