Best way to sand/polish out F4I wheels?
Been trying to search the forum to see what the best route is to strip and sand the wheels down to a mirror finish and was wondering if anybody has a tutorial with pictures or from another forum? How much time should it take to just do the wheel lips? Thanks!
The wheel lips are essentially pre-shined. Just use some Kleen Strip around the edges and it should come off with a garden hose.
Past the lip, where the texture roughs up, the paint adheres much more strongly. I think you'll need some sort of wire wheel or something to get all the paint out, or else a ton of sandpaper and patience. Multiple coats of paint stripper didn't take everything off.
Here's a pic I took this week when I was stripping my wheels. The really bubbly part is the easy part.
You need a picture tutorial for taking sandpaper to your wheels?
1) Spray with aircraft remover
2) Let Sit
3) Pressure Wash to blast away loose paint
Repeat steps 1-3 as needed to remove all paint.
Then follow this:
http://www.honda-tech.com/showthread.php?t=1259115
2) Let Sit
Then follow this:
