Best HID kit to buy for a F4i???
I was just wondering what everyone's opinions were on HID kits for cbr's and so on. I know there are tons of threads already started but, I had no luck doing the searching I could on them.
Three or a few kits from ebay have somewhat caught my eye earlier. I've had good luck with car kits from ebay but, I've had zero experience with anything other than that (and doesn't help that I'm new to the bike scene lol).
So I figured I could post these three links of the two hid kits that caught my eye and see what you guys think. Or any helpful suggestions/tips on what way to go when buying hids.
First Link:
http://cgi.ebay.com/ebaymotors/H7-He...spagenameZWDVW
Second Link:
http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWD1V
Third Link:
http://cgi.ebay.com/ebaymotors/Hid-X...spagenameZWDVW
First Link:
Second Link:
Third Link:
RE: Best HID kit to buy for a F4i???
I bought these http://cgi.ebay.com/ebaymotors/SLIM-...spagenameZWDVW
and they've been working for about a year even after a crash.
I bought the regular ballast 5000k H7 kit, mainly after reading the write up by Blue Fox. I've had them for about three months and have absolutley no complaints. Plus they are only about $80 shipped, and relatively easy to install.This is that store's selection of H7 bulb kits: http://stores.ebay.com/HID-Outdoor-E...QQftidZ2QQtZkm
ORIGINAL: Funedude05
I mounted mine between the headlights and it fits almost PERFECTLY, i'll take a picture later if i have time but you need to take off the upper fairing to make it 10000000 times easier and will even take less time.
I was planning on mounting mine in between the headlights or under the headlight housing... but when i got it all taken apart, i couldn't fit mine in there. So i ended up just laying the thick ballasts in between the rubber ram air tube and the plastic cover. I'm sure the slim ballasts might be easier to install, but the big one's went in just fine for me.
I've been reading the forum for a few days so i figured my first post should be informative...
If you are not already aware of this, the color temp output of HID lights has an inverse relationship with its brightness or luminosity output. The majority of OEM HID lights are at 4300k which is a white light. This temp has the brightest output and the best visibility. As you go higher in temp the brightness and visibility will go down. Anything above 6000k will have a dramatic decrease in visibility.
You're discussing a 10000k setup which may look very cool with its purple color but, it will not give you enough light to see properly at night.
ORIGINAL: SjT
If you don't get the correct kits too, you're gonna cause a TON of glare for other drivers on the road. Most eBay kits do this... our stock headlights were not designed for HID...
