Bank angle sensor
Is there a way to by pass this sensor? I bought a used cbr and the light wiring is FUBAR. I added LED turn signals and wired it up nice and left those unconected because there was no sensor. Now the fuel pump wont turn on and those wires are the only thing not plugged in. Check all the fuses as well. Any ideas would be great.
yeah i think you are talking about the tip over sensor also, i just never have heard it called the bank angle sensor. but you have to cut all three wires and then connect the two outer ones, if you dont believe me you can go over to stuntlife.com to verify it.
good luck |
+1 on ars1986 stuff like butchering the bike...www.stuntlife.com is your toolbox
I like my tip over sensor. I've had the joy of being able to field test it. :(
you can also unplug it and jam a wire or paper clip or something into the 2 outer connections. that way u dont cut anything. but either way those outer 2 need to be connected.
honda calls it the bank angle sensor. which reminds me... my new one came in the mail a few days ago and i have yet to put it on...
u got a new one? dude how much was it? i went to my dealer to get one and it was like 90 bucks. i took my chances and got lucky with a used one.
not a new one. i meant to say another one. got it on ebay for like $20.
So i connected the outer wires and worked great, took it for a spin around the block and 2 blocks away i pull up to a stop sign and boom, it shuts down. So i looked at my wire job looks fine. No fuel injector prime and no starter noise???? Would a week battery shut my bike down after its started? I have power to my lights and blinkers???
What color are the outer wires?
