Bad gas??
alright guys, thanks for all the input. to answer some of the questions, no, i am not showing an fi light and the plugs were carbon fouled. i'm in south florida so the temps run from the high 90's to probably the 70's at lowest lately. i didn't notice any rust in the tank but i will give it a better look. when the bike was running properly and started on a cold engine, it would idle high until it got warmed up then drop down to around the 1000 range i think it was. now when i get it started with an open throttle and let it go, it starts at around the 1000 range and slowly drops until it stalls. but even when i give it gas, i can feel it hesitating a lot. also got a bit of white exhaust from the pipe which increases when i give it gas. again, the gas smelled unusual and had a pretty dark yellow color to it. when i changed out the fuel pump the fuel seemed to flow properly when the pump primed so i dont' think that the lines are clogged. again guys, thanks for all the help. i'll let you guys know if i get it figured out and what works.
