backward tire
RE: backward tire
ORIGINAL: maldy21
i am positive the wheel is on backwards. it is my front tire and the arrow on it is facing backwards and there is even a very tiny directional arrow on the rim, which is also the wrong way. so sould this affect my ride. i havent really noticed anything wrong with it until i cleaned it. will it mess with handleing? im working on getting some pics up.
RE: backward tire
Is the TREAD going the same way as the rear or backwards compaired to the rear..
I installed my qualifiers and had at least 5 guys tell me my tires were mounted wrong.Mainly because the tread pattern is different front to rear(the face away from each other).
As long as the ARROW on the tire side wall is going in the correct direction the tire is installed correctly.
RE: backward tire
tire is symmetrical, washers/spacers that the axle goes through are not. i think the brake side is larger than the clutch side, so if you put that sucker on wrong and starting tightening down, you'll notice that the front tire won't spin AND you have a nice dent around the center of the wheel...TADA!!!
but tahoe is very stand up guy...when i sold my spare set or rims...i gave up the good wheel...and kept the dented on! cause i'm like that biatches!!!!!!!!!
RE: backward tire
ORIGINAL: Tahoe SC
I didn't know you were 4'11" 363lbs. Wouldn't that make you a rectangle?
ORIGINAL: Tahoe SC
