Another Oil Question.
It's getting about time for me to change my oil, It was changed right before I bought it so it is about time. First question is how much oil does the bike even hold, and another is I believe I am going with the Amsoil but I don't know either to go with 10w-40 or go with 20w-50.
RE: Another Oil Question.
buy 1 gal/4litres, drain the oil, change the oil filter and then fill till the level in the window is between the low and high marks. don't overfill. once you fill it, close the reservoir, start the bike and see if the level goes down. If it does, top it off again. 10w40 is what the manual says and what many people use... don't know how 20w40 would work.
I am running ams oil 20-50 in mine right now. It working fine. Fact it not heating up so fast with the thicker oil. With the temp the F4I normal run at, if you were to be running the bike in older weather that might be problem. I'm sure I will get three changes in. So my last one will be back to 10-30
viva_brasil
06-09-2008 04:38 AM
