another headlight issue
After some ideas as the title says. I have a 2002 cbr600f. The dip beam and sidelight have stopped working. when i examine the bulb they appear as though they have burnt out. The main beam light still works though.
I have connected a new bulb nothing. I have checked the fuse under the seat, intact. Before this happened i changed the chain/sprockets, air filter and oiler filter. I cant imagine these have effected the lights. Ive read could be the started switch but cant see how when one bulb is working nor the relay. I have yet to stick a voltmeter across to check power to the light end. Any ideas are welcomed. |
Did you check the fuse with a multimter? I've had ones that look visually fine but they were dead. Start with the easiest things
Also check all connections thoroughly.
