Air FIlter Replacement procedures 02 f4i
Old Aug 11, 2005 | 01:16 AM
osopolar's Avatar
Default Air FIlter Replacement procedures 02 f4i
Well its been 21,ooo miles and its definetly time for a replacement. not sure if this is a difficult task, im sure it involves lower fairing and inner fairing, also will be using BMC or K& N air filter, If you have any info on the nessesary procedures i would greatly appreciate it , as would my engine.
Old Aug 11, 2005 | 01:41 AM
mustang's Avatar
Default RE: Air FIlter Replacement procedures 02 f4i
Take the 4 bolts holding the gas tank out. Lift the gas tank and take the bolts off the black cover, remove the black cover pull air filter and and install new one. I recommend 2 things. One use a k&n filter so you don't have to replace it that fast. Its easier if you have 2 people but it can be down with one. Someone can hold the gas tank up while you take the bolts off the black cover. Oh another thing I recommend doing this when the gas is about empty out of the tank makes it a little easier. Good luck
Old Aug 11, 2005 | 03:32 AM
osopolar's Avatar
Thanks for the Answer , has anyone else done it this way?
Old Aug 11, 2005 | 03:51 AM
Turboedsupe's Avatar
Yeah i did it the same way and had somebody hold the tank while i put her in
Old Aug 11, 2005 | 12:42 PM
96LoLyfe's Avatar
i just used a long file to hold the tank up while i did the rest, i was done in about a half hour.....really easy to do....
Old Aug 11, 2005 | 05:08 PM
osopolar's Avatar
Thanks mustang,96 , and turbo, for the Info will probably replace with K$N , cause BMC is twice as much , will probably to it myself with the file method. well see it get so hot out in riverside, ca , gotta be done by 9 am and my buddy's dont wake up till 12pm
Old Aug 11, 2005 | 05:37 PM
96LoLyfe's Avatar
no worries, alot of the stuff is really easy to do...
Acespad3
Feb 13, 2012 06:33 PM
jacked600
Jun 15, 2009 11:13 PM
usndocjaysin
Sep 21, 2007 10:18 AM
ampfp
Aug 9, 2007 11:11 AM
