Aftermarket Fairings
Whats the problem?
Your not being very specific.
Are the mounting points not matching up, are they not pre-drilled, whats giving you a hard time about putting them on?
If its the latter two, all you need is a dremel tool to enlarge or perfect the existing mounting bolt holes.
Use a fine sanding bit on a dremel to clean up the mounting bolt holes after you are done.
