Aftermarket Fairings
Any advice on getting these installed? I know a lot of it are not exactly the perfect fit. Anyone had experience on installing them? any advice? got an 02 CBR f4i
Details would help here, what brand did you buy?
Im not sure what brand it is. I got it from UK though.
Whats the problem?
Your not being very specific. Are the mounting points not matching up, are they not pre-drilled, whats giving you a hard time about putting them on? If its the latter two, all you need is a dremel tool to enlarge or perfect the existing mounting bolt holes. Use a fine sanding bit on a dremel to clean up the mounting bolt holes after you are done. |
Thanks for replying Joey:
I was able to mount the tail fairing, front tire hugger and the front fairing. However, both left and right side fairings are not reaching the front piece at all. |
