add horsepower
I don't mean to hijack the thread here, but it doesn't seem like anything TOO productive was going to come out of it at the rate it was going.
Anyways, I'm from Clarkson University's Formula SAE team and we are running an F4i motor in our car as we have been for years. Our problem (while this motor does make for one hell of a fast car) is that according to the FSAE rule book, our intake is required to be restricted to a 20 mm opening, which does limit the power output significantly. We were toying with the idea of putting a turbo on our engine to make up for the difference here, but we don't know where to start really as far as modifications to the motor to get started (we never really played with the motor much because our philosophy has been "Honda has done a s*** ton of research and development on their engines and their is no way that we are going to be able to make anything more powerful and more reliable than they already did.")
Any advice you guys can give us? I'm guessing a turbo on a bike really isn't all that common, but I'm hoping that someone, somewhere, will know a thing or two to get us started.
Thanks in advance for any help you guys can offer!
i know some guys are gonna come in here and talk this one down but regardless maybe i can help
first you guys need to look into custom fabrication a header to accept a turbo... due to weight, and the size of the f4i motor i personally wouldnt go any bigger than a eclipse evo3 turbo...
you will also need to make a turbo support because haning that much weight off the header alone isnt good.... you will probably need to go with bigger injectors as well... or you will start to run yourself lean
depending on how long you plan on running the set up and at what rpm you may want to get a oil cooler set up... ummmmm everything else is pretty straight forward... connect the exhaust side put a filter on the intake side and run ducting from the outlet side of the turbo to the intake
from this point on everything will kind of be trial and error.... hopefully not to much error or your engine will go poof....
f4i too slow
The one & only time I let someone ride my '01 f4i was when my boss asked if he could take it around the block one time. Since he had offered to let me ride his brand new Harley just a couple months earlier, (an offer I declined), I told him to go ahead, just be careful. He came back and said, "Damn, I thought this thing would be faster." I told him not to ride it like it was a Sportster, shifting at 5000 rpm. "Take it out again, shift from 1st to 2nd the same way you did this time, but then wind it up to 10,000 rpm before you shift again." I figured that would be exciting enough without getting him into too much trouble, or getting my bike totaled, lol.
When he came back that time his hands were shaking and he had a giant grin on his face. "Okay, now I get it.", he said. I was thinking to myself, " Yeah, you think you get it. Unless you saw the shift light, you still have no clue."
I don't think that's gonna help out the OP much but that's good info for the SAE poster
4 8x10s, a couple wallet sized and 1 poster size and we'll get back to you in a week
