6000K or 8500K headlights?
Old 06-18-2005, 09:56 PM
brancart1's Avatar
Default 6000K or 8500K headlights?
Hey i have a 02 f4i and i just bought the eurodezigns headlights, well they sent me the 8500K H7 bulbs. Will this work or should i return it for the 6000K H7 bulbs?
Old 06-19-2005, 05:24 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: 6000K or 8500K headlights?
They'll work -- just a different hue.
Old 06-19-2005, 05:33 PM
what about 4000 bluevision's? How to they compare to the stock lights?
Old 06-19-2005, 05:38 PM
If they're not a true HID bulb (ballast and igniter) then you're just getting a tinted bulb that mimics the color of a HID of a certain heat range. A lot of these bulbs do put out more light than the stock bulbs but would be put to shame by a true HID. Of course they only cost a fraction of HID bulbs and are a direct replacement (read: no farting around trying to find a place to fit the things). The only thing I suggest is to make sure the bulb you use doesn't pull more than 55W.
Old 06-20-2005, 12:15 AM
I have the 8500k bulbs on my 01 F4i and they are great. Bright, and blue but not too blue. Dont know if they are brighter than stock- but the blue/white tint seems to make night riding a whole lot nicer for me- and when the high beam is on, wow. The bulbs looks very similar to the actual HID lights on my dads BMW. Love em.
Old 06-20-2005, 04:00 AM
Yeah the bulbs i got are same as service manual specs. 12V 55 Watts. I haven't gotten around to putting them in hopefully in the next couple of weeks. When you said direct replacement, you mean that i just pull the old ones out and replace with the new right?
Old 06-20-2005, 09:42 AM
Ya -- they go in just like the old ones come out.
Old 06-20-2005, 10:22 AM
Sweet, I'll be following the service manual when I do the switch. Will i need to remove the upper fairing to put in the bulbs or can i do it without removing it, because from the look of it i can reach them without having to remove it.
Thanks
Old 06-20-2005, 07:28 PM
You shouldn't have to remove any plastics -- I'm not really familiar with the F4i but it should be similar to the RR. Pull the plug, remove the rubber boot, push the retainer wire in and to the side then it'll hinge down, remove bulb. E-Z . The bulb may be attached to another piece -- a screwdriver can be used to seperate them. ****Don't forget to use alcohol to clean the new bulbs before installing ... oil and dirt on the bulb can cause hot spots and make the bulb blow****
Old 06-25-2005, 03:14 PM
Well in the service manual it says to remove the air duct covers when you want to replace the bulbs. Its not very clear why, so I might give it a shot without removing the duct cover and if i run into problems i'll go back to the manual.
I can't get my hands on pure alcohol since i'm in a Muslim country and alsohol is banned here. Can i use gin or whiskey as an alternative?
Thanks,
TooL
Quick Reply: 6000K or 8500K headlights?
