$60 passenger footpegs with build in led turn signals
Cool
You don't think that you have weaken them too much by drilling holes, I suppose?
P.s.- no - I don't think that your GF is fat - I just worry if she (or any other passenger - like other females) get an idea from time to time to stand up on them...
- or when you do a wheelies from the back seat pegs...
Heres mine
http://www.youtube.com/watch?v=Htfn4mCxvyA
hasnt weakened em at all. Been riding 2up all this year.
Heres mine
Heres mine
I disagree. Mine is set up with peg signals and integrated. The pegs add on to the integrated, and help distinguish which signal is on since the integrated ones are so close to the center of the bike.
Mine are 3mm yellow these: http://www.oznium.com/prewired-leds Just wired together to single +/- for each side, then tapped into my front signal wiring (since I had to redo it for LED flush mounts up front).
Quick question, do you think a series of 5mm led will fit on the foot peg? I am not sure if the peg is wide (and deep enough) for the 5mm leds.
So you had to solder the wires and resistors to the LEDs?
Also, I have the same question for you, do you think a series of 5mm led will fit on the foot peg? I am not sure if the peg is wide (and deep enough) for the 5mm leds.
Thanks for the help fellas!!
