520 vs 525
RE: 520 vs 525
It also depends on the type of chain you're going to use with the sprocket swap. X-ring chains are inherently superior to O-ring chains. There's a lot of variables here, including the different sized sprockets, different number of teeth on sprockets, chain manufacturer/model, chain type, etc.
RE: 520 vs 525
oh he's going to use DID 525 chain with vortex sprockets...but it won't be steel...but it'll still last as long.
there are not recommendations...YOU HAVE TO GET THESE...or else your dog and gf will turn into a pumpkin, and after reading this message you have to tell at least 20 other people, or you'll get premature wear on your sprockets (not on the chain cause DID is da KABOOM..)
RE: 520 vs 525
well when i decide on either -1+2, or just a +3 I think I will be happy. Gonna stick with the 525's, why change what works, course I was gonna get a DID, with vortex sprockets. I was happy with the 12k miles I got on the stock chain within a year of buying it.
Not having a good pay period, this time round, winter time cleaned my bike, was getting it all ready for new chain and sprockets, cut the chain, then like the next day I roasted the pinion gear in my pick up, big $$$ for both, but my priority is on 2 wheels, not 4.
RE: 520 vs 525
ORIGINAL: thirdgenlxi
Well I've only had my 520 on for about a month or so, so it hasn't really had a chance to wear of any significance yet. I did have to adjust it just a hair the other night cuz it was a little loose, but I figure since it's new it's gonna stretch a little bit initially regardless. A friend of mine used to have a Busa (has an RC-51 now), and it had the 520 chain (originally 530), and he said it stretched the chain out pretty quick. A Busa makes ALOT of power though, much more than an F4i, so might be alright on ours. Guess I'll wait and see too!
A busa or a liter bike should usually use a 520 anyway, it is too small. Unless it is for racing and you don't mind putting a new chain on every race. For the street, it or any liter bike should have a 525 or higher.
RE: 520 vs 525
ORIGINAL: bikesnjeeps
in regards to the other things...depending on if you do it or not, like i said before, your gf and dog will turn into pumpkins. think about that.
