4000 mile check up
4000 mile check up
I was wondering if anybody knew what was involved in the 4000 mile checkup, I'm overdue and I cant get a straight answer from the stealership. If they want to charge me 250.00 for just checking all the nuts and bolts they can forget it. I wanted to take it to an independent shop and just have them inspect the bike. What do you guys/gals think?
RE: 4000 mile check up
Well, according to the service manual, the only thing they check is the idle speed, brake fluid, brake pads, clutch free play, and drive chain. The service manual doesn't even mention an oil change. These are really all things that you can probably handle yourself.
Hopefully others will chime in.
ORIGINAL: Streetdemon
+1 - No need in wasting your time and money.
ORIGINAL: fishfryer527
Don't waste your money. Change the oil yourself, keep the chain clean. When the bitch breaks, then fix it. Until then don't worry about it.
