2006 CBR 600 Engine Swap into '99 F4i Advice
The "timing" is the exciter wheel I haven't taken off the cover on both engines just yet to see if they're the same size/design or anything yet.
As I mentioned above somewhere I am keeping the carbs, does anyone know if I can just keep the fuel pump from the '06? Or do I have to use the '99 fuel pump?
Thanks for all the replies I appreciate all the help and support
I ran into possibly another issue. The '06 head obviously has a cam sensor on it, will I be able to not plug that in and not worry about it or would it be better to put on the '99 head?
(Engine block on '99 had a hole in it below the head)
