2005 cbr 600 not starting
I have a 2005 cbr 600 and it ran fine and when I switched the battery over it doesn't want to start, I can hear the fuel pump turn over but just doesn't start! I have drained the gas and put fresh gas in and doesn't start and I even have sprayed starter fluid and still nothing! I have checked the battery and the battery is good ! & also the bike has been laid down but ran fine and started up fine all the way up till I changed the battery! & also I'm sorry I'm new to the forums and also working on motorcycle but I'm willing and trying to learn how to work on these thanks for reading |
Have you checked to see if your getting spark? |
I'm assuming you mean the engine is cranking over but will not fire up and run? Just changing the battery doesn't affect anything, so look elsewhere like anywhere damaged during its previous crash. You didn't hit the kill switch by accident did you? I never use it and sometimes hit it without knowing and then can't figure out why my bike wont start haha.
Originally Posted by E.419
(Post 1312334)
It was the spark plugs |
