2004 wiring mess
Old Sep 18, 2023 | 10:12 AM
Scott91370's Avatar
Originally Posted by Timporatron
Welp…it starts!! You guys knocked it out the park...
That's what @dannoxyz does! There is so much knowledge in that head it's crazy!!
Old Sep 18, 2023 | 12:14 PM
dannoxyz's Avatar
Why thank you!
Oh forgot, one thing to watch out for is bypassing clutch-switch permanently. It was discovered on CBR600RR & CBR1000RR models that ECU uses basic idle maps when clutch is squeezed. Leaving clutch-switch bypassed leaves it in this mode and yields sub-optimum fuel & ignition values. So bypass kickstand only and leave clutch switch line open.
Old Sep 18, 2023 | 08:09 PM
Timporatron's Avatar
Oh shoot ok
Old Sep 18, 2023 | 08:10 PM
I also don’t have a o2 sensor plugged in. And It seems my fuel pump isn’t priming but it startS with starter fluid
Old Sep 18, 2023 | 09:37 PM
Spoke too soon, fuel pump works, surprisingly. It looks all rusted inside and stuff but hey I’m juiced.
so I’ve decided that I’m gonna put it in my Jetski..gonna be a weird one but gonna try
Old Sep 18, 2023 | 10:07 PM
dannoxyz's Avatar
That's gonna be one wicked jet-ski!!
Old Sep 19, 2023 | 01:30 AM
Hell yea! If I can make it work! For it to be balanced properly it gonna have to sit inside of it just like it does on the bike and i mind as well utilize the gears since I cant direct drive it and I’ll have to figure out some type of 90degree 1:1 gear box that’s strong enough to handle it. Possible make a lower profile intake box and cut and weld the exhaust to have them come out the side maybe. Oh and figure out a gas tank with a comparable fuel pump. I Got my work cut out for me.
is it possible to eliminate some sensors and vacuum system so I could just have the throttle body velocity stacks? which would give me a lot more room to work with. That would probably require a
tuneable ECU huh
Old Sep 19, 2023 | 01:18 PM
dannoxyz's Avatar
Need to connect O2-sensor heater circuit so ECU won't have a fit. This is how it's done on-bike, you can trace heater-circuit in diagram and connect 2 ECU terminals with resistor to simulate. Also related thread: https://cbrforum.com/forum/new-membe...3/#post1354014
Only vacuum needed is for MAP sensor and that's tapped from throttle-bodies. Can remove airbox completely and use velocity-stacks & pod filtres instead.
Easy enough to replace ECU with programmable Microsquirt. Can actually re-use factory crank & cam-sensor. Not really needed unless you've got some crazy mods that factory ECU can't compensate for. Although you can gain quite a bit of power by leaning out factory mixtures and bumping up ignition-advance a little. It'll be extra rich without O2-sensor connected.
Old Sep 19, 2023 | 11:21 PM
Damn you really do know everything about these motors. I feel like I owe you some money lol thanks bro
Sociofraude
Jan 14, 2022 10:40 PM
66p
Aug 31, 2020 01:31 AM
CorruptFile
Aug 1, 2019 07:06 PM
coldflood
Oct 16, 2011 10:31 PM
antatious
F2 Tech
Feb 21, 2011 05:32 PM
