2003 CBR600f4i - Not starting
Old Apr 11, 2018 | 10:16 AM
Dee Nice's Avatar
Exclamation 2003 CBR600f4i - Not starting
Whats happenin CBR fam...So I'm working on my recently acquired bike, however I've encountered some issues along the way.
Novice mechanic --- Manly 4 wheeled cages, also known as cars and trucks
2003 CBR600f4i about 18,000 miles on it
-Sat for 1.5 years in garage
-Only need a regulator rectifier per previous owner, who happens to be my lil bro.
-I also have the Haynes manual in color for this bike
So work that I've done...
-Replaced Regulator Rectifier
-Replaced Spark Plugs (NGK iridium of course)
-Replaced Gas Full Tank (87 to start)
-Oil Change (Full Synthetic)
-Coolant Flush (Engine Added)
-New Battery
-Bike is currently in my garage on bike stands
Of course after doing all of this, the bike won't start
-Fuel Pump does not prime
-Tried jumping fuel pump relay, nothing
-Did feel fuel pump relay "click", but not priming
-No rust in gas tank either
-No gas going to fuel rail
-Fuel hose looks/feels dry
-Took hose off of fuel rail, no leakage from tank?
-Checked all fuses...none blown
-Wiring Harness looks good
-Instrument Cluster lights up normally
-Headlights work, well the high beam does currently
-Thinking the normal headlight is out?
-Kill switch relay works, hear click
-Bike does crank/turnover
-Bike does not start
I think that's it...any assistance the CBR fam can provide is greatly appreciated.
Dee
Old Apr 11, 2018 | 10:41 AM
74demon's Avatar
Fix the low beam headlight. IIRC, the BAS runs through it.
Old Apr 11, 2018 | 01:12 PM
Dee Nice's Avatar
Thanks for the quick reply 74demon.
I hope it's that simple...lol. I will check that tonight.
Old Apr 15, 2018 | 09:35 AM
Dee Nice's Avatar
Update...so in looking at the headlight wires they looked ok, once I actually felt it, I knew something was wrong. The wire was way too stiff, and the connector on the ends starting breaking off while try to unplug the connectors. I will update with more info once completed.
Old May 9, 2018 | 09:23 AM
Dee Nice's Avatar
UPDATE...so I replaced the headlight wires...had one of my boys, who actually works on and races bikes, take a look at it. He said I need a fuel pump. Ok I called Honda and they said 480 for the fuel pump...$480, it's for a bike not a car...Any other suggestions on where to get a reasonably priced fuel pump in working order for a 2003 honda cbr600f4i???
Old May 13, 2018 | 11:11 AM
Claytonj95's Avatar
Ebay
Old May 16, 2018 | 08:45 AM
Dee Nice's Avatar
Originally Posted by Claytonj95
Ebay
I checked Ebay and of course they have all sorts from $35 - $250, I just don't know which one to get. It just seems weird the price range is that much of a difference. Any suggestions? BTW, apparently the fuel pump went bad because of the old gas sitting in there for about 2 years. I did try to jump/bypass the fuel pump to see if it would prime, no dice.
Old May 21, 2018 | 05:15 PM
boredandstroked's Avatar
Originally Posted by Dee Nice
U$480, it's for a bike not a car
How does that change anything? Car or bike its still an electric pump that moves fuel at a pre-determined rate and pressure. Besides, bikes are low volume, so price per part is higher.
Either find a used one or buy oem. Don't get a chinese ebay one if they are even available.
Old May 21, 2018 | 06:25 PM
74demon's Avatar
Try this place
https://www.partsgiant.com/p350419-k...g-25&r=c-23739
Forum sponsor. Discount for forum members... Contact for details.
BlackDogIron
Sep 14, 2017 05:47 PM
Jakob Simmons
May 5, 2017 09:07 AM
Joey
Aug 21, 2012 02:41 PM
