2003 600 f4i Gasket question
Hey i noticed that i have a small oil leak coming from the crank case cover on the right side of the bike. the oil is leaking onto the exhuast.
I need to take care of this problem asap so im wondering if there is a accual gasket? or is it a permatex (liquid gasket maker)? |
anyone?
I don't know if there is an actual gasket or not. I would guess yes. I had to replace one there on my F2. Permatex will (and did) suffice. Good luck.
If your talking about the side were the clutches are, then it's only gasket maker. I used permatex high temp gasket maker. No leaks so far.
yeah i just did it today, no gasket, i used permatex black rtv gasket maker. worked perfectly
