2002 F4i no fuel after R/R Failure
#21
Only thing that i realized after is that wiggling the connector doesn't make the FI light go away, it was just plugged in loosely at the connector. The other thing is that disconnecting the black connector from the ecu makes the FI light go away.
#22
Alright. I tested my ecu in another f4i and exact same thing. As soon as you press the kill switch the fuel pump fuse blows. So I definitely need an ecu. Should I take the rest of the harnesses apart and check for more shorts? I don't really want to take apart anymore than I have to. Do you think it was a short that fried my ecu or the R/R failing and sending 40-50VAC to my whole bike...
Gonna go into the honda dealership today and explain I'm not very happy that their less than a year old part fried my ecu.
#24
Yup. Fuse doesn't blow, when I hit the kill switch you just hear the relay click. As soon as I plug in the ecu it blows the fuse. Is it safe to say that the ecu is the culprit and I can replace it safely ?
#25
#26
#27
Meter in volts AC and then move the leads between the three prongs on the stator? I've heard that you have to rev the bike to about 5k to get a proper reading.
Edit: where is the ground on the stator? I only see three yellow prongs. Is the stator grounded to the frame?
#28
#29
Ride safe
