Got myself a 2002 F4i in pieces that would crank and not start for a great deal. supposedly all the pieces were there. (they were not) Had LOTS of wiring issues (at least 50 butt connectors with different color wires on either end). After about 20 hours of diagnostic and rewiring it starts and runs. WooHoo. A million thanks to a thousand threads on this forum that I read.
Now to reassemble. Turns out, among the many things I'm missing is the "undertail" or "rear fender." What is that part actually called and is there a secret website to find them at. It's the black plastic that holds battery/PCM and the fairings mount to it. Also is that piece specific to the dual seat setup because those are what I got? If I get the banana seat version will it work well enough to get it on the road? I'm not looking for perfection here.
Do a trawl on here, I'm sure I have seen a guide to swap from dual to banana somewhere.
You would need the subfame / seat and associated bits and bobs.
That's exactly what I've found on here. Only problem is, I already have all the stuff for the dual seat except for that one plastic piece. I'm going to attempt to fabricate something out of aluminum I think. Ill post some pictures if I can manage to figure out the exact measurements. I see a lot of Cardboard Aided Drafting in my future.
I'm pretty sure that's for the carbureted model. The title says F4I, but the description says F4 and doesn't look like the ones I've seen for the F4I. I believe it needs 2 holes on each side for the rear fenders to mount to.
Side note: I did make a crude battery box and bolt it to the frame for a test ride. Bike wouldn't rev over 6500RPM. Then after about 3 miles it just died. the main power fuse (20Amp that's in it's own little plug box) pops as soon as I turn the key on now.
Oh, that's everyone's opinion. It's why the parts are hard to find. People swap the whole subframe from the 01-03 f4i's onto later models to get that look. That's why they're so hard to find. Even broke down on the side of the road, missing several pieces it still looks better than the banana seat. Lol
