2002 F4I Forks
2002 F4I Forks
So I bought some forks off of ebay a while back, and as I was rebuilding my bike, just noticed yesterday that they are slightly bent. Such as when you roll them across a table, there is about a 16th or so of an inch of a gap showing. What would you guys recommend to do? Trash the forks? Are they fixable at all? Any help would be great. Thanks
this is my way to tell if they need replacement or not- find a way to support the bike w/ the front wheel off the ground. loosen the upper and lower triple clamps for one side and try to rotate the fork tube around 360 degrees. repeat for the other side(after you tighten the first side back up). if you cant roate it fully, replace the slider.
