Webby64 |
10-23-2018 10:00 AM |
I bought a 03-954rr & had some same rising defects
Not that i'm saying you have the same, but i bought a 03- 954rr, & the fuel set up is much the same, & i had almost the same defect as you although i had many others, But 1st thing is getting the manual for that model, my RR-3 would do the same - when it 1st started up being EFI when cold start ups it was like a auto choke running 500 to 750rpm higher than normal, but when the RR-3 would warm up the idle wouldn't be stable & some times snuff. At 1st i tried to adjust the throttle cable but that didn't work, then i kept trying to adjust the idle knob but that wasn't working either. So i bit the bullet & ordered on line because after market parts ordered on line are so cheap it's the best ( But you must be 100% sure of the parts you are ordering) so i ordered a new RR-3 fuel pump & strainer. 8mm hose's & clamps ($12). 100cm of 6mm high pressure fuel hose's & clamps. 8mm outlet & inlet high pressure fuel filter ($12). fuel injector cleaning tool ($7), A spray can of carby/throttle body cleaning fluid ($15). So I replaced a new RR-3 Spec fuel pump & 8mm hose's & clamps, new fuel filter & strainer, also had to clean the sludge from the fuel tank , removed all 6mm fuel hoses & clamps, disconnected the fuel rail & fuel injectors cleaning fuel & regulator with spray can of Carb/throttle body cleaner, then using injector cleaning tool with spray can of carb/throttle body cleaner reverse flush (front to back) clean all injectors first & then flush injectors (back to front) reassemble injectors & rail to manifold. Then replace all tank to fuel rail & regulator to tank 6mm high pressure hose's & clamps. For me? This fixed all my performance defects & it being the same set up as my RR-3 , this at least can give you a good place to start. As i got my RR-3 back to it's 100% performance for less than $50, where the dealer's service shop said it's this & that, which will cost me $1750 to get the RR-3 back working 100%. All i can say is take your time & if your stuck? just go on line & look it up & you will always find how to do it . C.Webb
