2001 F4i starts but wont keep rev and dies
Old 05-20-2014, 09:34 PM
Question 2001 F4i starts but wont keep rev and dies
Hi,
This evening, while coming home - my F4i died at full throttle. It just gave up power while in full throttle. After pulling over, I observed that all the lights in the dash board (indicators, red light, hig beam indicator etc) shows lit. I could not understand the problem. Anyways, I tried starting it and starts just fine. BUT, dies immediately as the rpm goes to 0 right away. It happened multiple times.
Please suggest,
thanks
Old 05-21-2014, 04:13 AM
NewSense45's Avatar
Maybe it is a battery issue??
Old 05-21-2014, 05:52 AM
74demon's Avatar
Fuel pressure regulator?
Power commander? (if equipped)
A little bit more information on what its doing would be helpful in narrowing it down.
Old 05-21-2014, 09:04 AM
I had a brand new battery two months ago. So, it may not be it. If it is battery, it should not die while running I guess.
Old 05-21-2014, 09:07 AM
thanks for the reply,
After it died, If I turn on the ignition - all lights, indicators in the display stays lit. When I try to start it, it starts fine but I had to rev the throttle to keep the rpm. As soon as I release the throttle, the rpm goes to zero and the engine stops. The bike had all fluids replaced + tire change (not relavent) + Cam chain tensioner replaced by Honda show room at about two months ago.
thanks.
Old 05-21-2014, 10:54 AM
74demon's Avatar
Is the FI light on?
Old 05-21-2014, 11:03 AM
Is the FI light on?
Yes, all lights on.. not particularly F1.
thanks
Old 05-21-2014, 11:10 AM
74demon's Avatar
thanks
While its running?
Have you tried to see if there is a code stored in the computer?
Old 05-21-2014, 11:15 AM
While its running?
As soon as I turn on the battery (before starting the ignition) and stays like that even after the engine starts.
How do I read the code in the computer?
thanks for your time,
Old 05-21-2014, 11:40 AM
74demon's Avatar
The light is supposed to come on with the key. After the bike is started, it should go off within a few seconds. When it doesn't, it means the ECU picked up something out of its expected values. It the stores a code pointing to the system that the failure is in.
To retrieve the code, use a piece of wire or paperclip to jump the diagnostic connector under the seat. Turn the key on and count the flashes. Long flashes are 10s, short flashes are 1s. Two long the three short would be code 23.
If you download a service manual, it can explain what to do and what thing mean better than I.
Let us know what code come up.
Quick Reply: 2001 F4i starts but wont keep rev and dies
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
