2001 F4i gauge issues?
Recently picked up an '01 F4i..and the gauge is very weird.
Does not display the odometer/ speedometer...but shows the tachometer just fine.
At the initial start-up....everything seems to be functioning.
I remember going slow at one point and the speedometer functioning..but stopped...
Any advices? or just take it to a shop
It's an electrical issue somewhere. First check where the harness plugs into the gauge - look for any bent pins, corrosion, etc.
You're most likely just gonna have to do a lot of searching around wires to find the culprit. A multimeter will probably help as well.
Does anything else display on the LCD? Does it light up?
I'm still new to the bike so I wouldn't know where to start.
Is it best to just purchase a manual?
Thanks man.
I just went riding a bit more today.
Weird thing is...when I mashed a bit...the speedometer all of a sudden started showing up...
But then stopped showing after a couple of seconds..I'm guessing loose connection?
Also...I don't get why my bike rattles around 4000 rpms...but after that it's fine. LOL.
