2001 F4i Build
Old 08-24-2015, 09:37 AM
Conrice's Avatar
I have parts from all the big 4 (and some of the euro brands too) on my bike.
Do it.
Tokico brakes are Tokico brakes, not Suzy's brakes.
Likewise, Showa forks are Showas.
I don't know if I'd like having a giant "S" on my triple tree, but some epoxy, sandpaper, and a rattle can make that issue disappear.
Old 08-24-2015, 05:35 PM
Conrice's Avatar
I guess I should clarify this.
I'm not saying all Showa forks are the same, nor Tokico brakes. The manufacturers do specify how they want them made.
But the point is, if you want nice USDs on your bike, and the ones off of a Suzuki are close to the length, go for it. Make sure they're sprung close to the same too (but I'm sure you took that into account). And as far as brakes, you do need to know what kind of master cylinder bore Suzuki was running to make sure you'll still have an ideal setup for that as well (if you're not completely swapping over the entire front end).
Old 08-25-2015, 04:10 PM
98ej8's Avatar
Default 2001 F4i Build
Thanks Ive been doing some more research and I'm trying to stick with everything Honda to make it simpler. Rc51 front is what I'm aiming for now, close to almost 2 inches longer forks than a 1000rr. Front end swap is scheduled for winter season so I'll try to get more details and pricing before I start ordering.
Old 08-25-2015, 06:03 PM
Conrice's Avatar
An RC51 front end is pretty sweet. Are you going to use an RC51 front rim, too?
Old 08-26-2015, 12:17 PM
98ej8's Avatar
I'd like to use both rc51 rims but that's if I can source them for a price I can afford...
Old 08-26-2015, 07:06 PM
boredandstroked's Avatar
Don't most people who do this use 929/954 front ends?
Old 08-26-2015, 11:12 PM
Conrice's Avatar
Ah, and it is a challenge, they want an arm and a leg for them. But there's a slew of other rim options to utilize if you can't get them.
Old 08-27-2015, 04:52 AM
98ej8's Avatar
Yeah boredandstroked, been looking at 954 front ends, more common on Craigslist around here. My main concern is that the forks are close to the same length as my stock ones so I don't change the rake much.
Old 08-28-2015, 12:50 AM
98ej8's Avatar
Before and current pic.
Old 08-28-2015, 02:32 AM
98ej8's Avatar
So after doing some more reading I'm leaning towards just rebuilding the stock forks with Ohlins internals. Steering head on the frame is designed to work with these forks, I don't have to worry about steering geometry changes, no need to look for parts to swap. Also planning on buying Galfer rotors, pads, and SS lines sometime in the future.
Quick Reply: 2001 F4i Build
