2001 cbr 600 f4i ticking noise?
It somewhat gets worse with the rev curve as you can tell in the video 0:14
what is the difference between cct and the lifter? i thought cct was short for cctl hence lifter... ?
as in the Cam chain....They are indeed 2 parts...the #4 Tensioner itself is an automatic adjusting one and have been had problems. both parts have played a role in this ever occuring issue that many of these bikes are plagued with. Be it the tensioner not putting enough on the lifter #3 or the lifter being worn, etc... This is more than likely your issue. There is a fine solution in a sticky at the top of this forum. Very common at your mileage btw. There is no real harm at least this seems to be the general consensus..(obviously breaking the chain is very harmful.I Just mean the sound...)..however it is annoying,,and if there is an obvious issue it will get louder as time goes on. Either buy a new one or get a manual APE but either way it is not a 5 min. fix....do your homework.
I dont really feel like digging into that just yet as im not that experienced with wrenching on these types of bikes yet, but ill check it out if it gets louder with time. thanks alot for the clarification
cbrmark
04-30-2015 02:48 PM
XxCBR_SILVERxX
10-24-2011 08:28 AM
