-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   2 flash fi code (https://cbrforum.com/forum/f4i-main-forum-11/2-flash-fi-code-143852/)
chute Dec 26, 2012 03:42 PM
2 flash fi code
So ive been battling this weird problem the last 2 months. I was taking my airbox off to get to the cct and decided after I took it off that I didnt want to deal with changing it and took it to the shop the next day. I pit it all back together but since then if its cold outside or it rains and my bike is outside. I get really low idle for about 10 seconds then bumbs up to normal idle. Then 2 flashes, it didnt happen for almost a month then Last night happened again. I took the airbox off again and undid the map sensor and redid all the conections on friday. It rained last night and happened again. My gas mileage has gone to 120 a tank the last few months since then. Is there anythijg else I shoupd do? Why is it only happening very little and only when its copd.
RudyGT Dec 26, 2012 04:50 PM
on the left side of your airbox there is your map sensor, there is a hose that plugs into that as well as the wire connector. right in the bottom.
there are 5 hoses that go into your airbox, and 2 sets of wires.
chute Dec 26, 2012 10:25 PM
I know where the map sensor is, I'm trying to find out if there is anything else I should check, the hoses are fine, I've checked all connections and blew them out to make sure there was no leaks or anything in there.
stlcbr600f4_newb Dec 27, 2012 01:13 AM
check all your vac hoses the sensor may be bad
rd91si Dec 28, 2012 07:44 PM
Under the seat there is a 2 wire plug for checking codes, jump the wires turn on the key
to retrieve the codes.
GK45011 Nov 10, 2013 07:33 PM
jumpig wires
Does anyone have a picture of this plug? If I simply turn the key (not starting the engine) I am getting a repeating two long flash, followed by 3 short flashes. Is this the code? I haven't jumped the wires so I don't know if this code is correct.
If this is the correct code, what does it mean?
Thanks for any help,
Gary
Kopi Ko Nov 10, 2013 08:07 PM
Gary
23 is faulty oxygen sensor heating element
GK45011 Nov 10, 2013 08:53 PM
I am running a gpstyle short exhaust just past the 02 sensor. Did the extra heat toast the 02 sensor? Is the heating element different than the actual 02 sensor?
Can I use a 02 eliminator with out pcIII? to solve this issue, or will I harm something else? I am new to the CBR so any help is appreciated.
Gary
