-1/+2 vs +5
a 50 tooth rear is a +5 over stock right? i think stock is a 45 or 46. but i could be way wrong. do you have any pics of the setup? the main reason i consider it is mainly the looks. if not id just do a -1 +2. also it sounds like theres a lot to consider when it comes to rotating masses and such. im just doing mainly joyriding so i dont know if itll come into play too much to be noticable. but to chime in-wouldnt it be similar making the front smaller and the back a little bit bigger? it might not be as drastic looking of a change but the ratios would be the same-wouldnt they? so would the force be the same on both setups?
I understand the idea of greater rotating mass, although for our purposes a few extra grams aren't drastic, so I don't understand why it's an issue for some people.
Secondly, technically there is no centrifugal force. It's not really a force. For all rotating bodies, the force points towards the center of the object. The "force" that pushes an object towards the outside isn't it's own force, but the change force lagging behind movement, or so I understand. The amount of torque applied I didn't think of, and you're right on that, but isn't that desirable?
Wouldn't the summation of torque be equal if you go either way? So the only applicable down side to street riding would be a larger chain?
Well if it creates a larger torque accelerating, that means it needs more force (or power) to get it to accelerate, same with deceleration.
You guys are all missing a basic issue - if you use +5 on the rear YOUR CHAIN WON'T FIT
A bigger chain has more flex, and is an expensive replacement (much more than sprockets, where I live..........and you don't fit a cheap chain to your bikes, do you ?(unless totally broke, in which case where did the new sprockets come from)
GOING SMALLER -1 ON THE FRONT = +3 ON THE REAR
If you go -1front which is almost the same ratio as + 3rear, and go +2 on the rear, chain will probably still fit That'll give you +5 effective change on the rear, as far as I know......
FWIW
FWIW
