06 f4i wont start need help
it my friends bike the bike is an 02 the motor we were told is a 06 put the motor in and it ran great for 3 days and now it wont start i pulled the plugs replaced them and checked for spark by putting the plug to the bare frame no spark. where do i go from here keep in mind i have my bike 100% running order so i starting swaping parts first i tryed ecu them the box that is bolted to the subframe then i swaped the ignition and still nothing SOMEONE PLEASE TELL ME WERE TO GO NEXT !!!!!!!
RE: 06 f4i wont start need help
Before you go swapping out every single part, use a multimeter to make sure that the proper components are getting electricity. Will the headlight turn on when you turn on the bike? Is the engine switch turned off (don't laugh, took my buddy an hour and a half to figure it out once)? A little more info will help us out, not just what you've done but what specifically are the symptoms.
If the bike was working "fine" before there is a high probability that you do not need a lot (if any) new parts, just some more investigation...
C Jacob W
07-29-2013 11:03 AM
