06 clutch
06 clutch
My clucth was slipping a little a couple months back, and the other day it was realy bad. Any gas i gave it it would just slip. I pulled the clucth today. The first clucth disk was all most worn out on the one side of the disk,but the rest are fine way above the sevrice limt. When looking on line at the oem manual, the first disk for the front is green the next 6 are purple and the last one had a bigger id. Is there a reason the first one is green, are they all the same or is the first disk thinker or some thing. Will one bad clucth plate realy make the bike slip that bad. I am going to replace them all but figure i would ask. Springs are ok so are the clucth plates. 2006 10200 miles yes the clucth should have lasted me longer but been beating the heck out of it i should no better. I did not try to adjust the clucth befor i took it apart, figure it was slipping so bad i would take a peak.
Zandaloo
08-22-2013 03:26 PM
Bordo
09-21-2012 07:33 PM
02f4irider
03-06-2009 07:50 PM
