06 CBRF4 Random sputter
Hey everyone!
It's been awhile since I posted but military life has had me busy, and not able to ride much. But I need some guidance. I recently did a sprocket conversion my bike and on a recent ride with some friends we were cruising at around 85 when I noticed my bike kind of struggling. Nothing crazy but I felt it losing power and my RPMs were around 7000-8. This is t the first instance but when I exited the highway and was accelerating in 2nd I almost lost all power. Pulled the clutch, shifted, and she worked fine. Stopped for a minute and ride home feeling the same sputter. Any ideas what to look at? FYI I also installs some demon eyes about a year ago I'm wondering if it's electrical.... Thanks in advance for any help!! |
Nothing??
Originally Posted by NewSense45
(Post 1287912)
Nothing??
I don't know much about bikes mechanically but I have my fair share of knowledge with cars so I will try my best... -When did you last change your sparkplugs/tune-up? --were they OEM plugs? -Does this happen when you use a certain gas station or with any? -FI light coming on? -Fuel pump/injectors ever been replaced? Not sure that these will help but hopefully they get you on the right path. Good luck |
definitely check/replace spark plugs if they havent been recently. also check your air filter if you're concerned about anything electrical, then measure voltage on your battery while the bike idles, if everythings working as it should you'll have 13.5-14vdc.
also you said you havent riden it much lately, did it have old gas in it when it did this? This year when i first took mine out, overall ran good, but a couple times she'd sputter and the FI light would blink then it'd be fine again. since putting fresh gas in her i havent had an issue with it. |
Originally Posted by Colombo
(Post 1287920)
I feel your pain, this is the absolute deadest (is that a word?) forum I have ever been a part of with the least replies and help. I've asked tons of questions in my threads and hate that weeks go by and not a single answer, almost tempted to stop wasting my time coming here...
I don't know much about bikes mechanically but I have my fair share of knowledge with cars so I will try my best... -When did you last change your sparkplugs/tune-up? --were they OEM plugs? -Does this happen when you use a certain gas station or with any? -FI light coming on? -Fuel pump/injectors ever been replaced? Not sure that these will help but hopefully they get you on the right path. Good luck Hey, yea it used to be really busy on this site. I been away from it and I am surprised how deserted it seems to be.... Anyway, no no FI light, Injectors/Pump havent been replaced since I have owned it. And it happens regardless of gas... I am starting to think electrical, but I havent hooked up the voltmeter to it..... Thanks for the response though man! I will hook her up today and let you know what I find out. |
Originally Posted by sjona2011
(Post 1287922)
also you said you havent riden it much lately, did it have old gas in it when it did this? This year when i first took mine out, overall ran good, but a couple times she'd sputter and the FI light would blink then it'd be fine again. since putting fresh gas in her i havent had an issue with it. Spark plugs were just changed last summer. I might not have rode much, but I started and rode her at least once a month in between the seasons. |
(Post 1287992)
Thanks for the advice, what should I have the voltmeter set at when measuring? like it has a bunch of options...(v with wavey line, v with straight/dotted line, mV etc.)
(Post 1287999)
the meter should be set on the VDC(v with the straight/dotted line) and should read 13.5-14vdc at idle.
Well...
I hooked her up and finally checked the battery. It's reading just over 14 @ idle. Any other things to check?
