02 F4i Front/rear seat ?'s w/ pics
I just picked up an 02 F4i, it runs strong but definitely needs some TLC..
Anyways the front seat is obviously missing its bolts,, the two plastic tabs is where it bolts down correct? 8-10mm bolts?
So basically I have to remove the undertail/tray to bolt it down?
Im not sure but it has a black plastic undertray/tail with it, aftermarket or not it keeps me from being able to get to the bolts for the front seat.
Also another PITA is the rear seat lock is broke, probably because somebody broke the "hook" that latches it down I guess. Im assuming I will need a whole new locking mechanism? It looks like where the rear seat "latches" is part of the subframe.. so hopefully it's not a big issue.
These may be dumb questions but I need to get these seats fixed before one comes off cause I plan on riding it daily. Heres a pic of the front and rear seat
Front:
Rear, with what looks like the mechanism that latches the seat on the subframe is broke off
Front:
No, you simply tighten down the seat screws into the subframe. Place front seat into proper position, lift corner(s) of seat & tighten down screws into subframe.
If you're missing parts, you can get those from bikebandit as well.
Well when I lift the back of the seat I dont see the tabs... I see the ones that face downward, I dont know how I would get at those from the side because they lay flat on the subframe.
And I also notice I am missing the final part of that cable, the part that hooks onto the subframe and latches the seat. Thank you for the pic that help solve that question.
Took a pic for you to understand what I'm saying. As the seat sits in its proper postion, you lift the corner of the seat to secure w/ the screws. To *secure* - tighten down screws...to *remove*- unscrew them & remove...easy as that. Also, you can see both the screw & the screw-collar tightened down on the seat's plastic tab. You never have to access the bottom of those screws b/c they tighten down on their own against the plastic seat tab against the subframe.
Yep, you can use a piece of safety wire around the seat's hook that would normally be latched, & secure it to the subframe bar. It will take some doing but you can access it by removing your front seat & reaching up thru the trunk area. It won't be easy but you can do it. Otherwise, you'd have to remove part of your FE to get to it.
oodayvidoo
06-14-2012 10:05 AM
