02 f4i died while riding and won't start, weird symptoms
Old May 6, 2017 | 07:58 PM
midnightlaws's Avatar
Default 02 f4i died while riding and won't start, weird symptoms
ok I was taking out my bike for a ride and it died after like 40 ft. I didn't stall it it just died. Starter button did nothing at this point so now I'm like wtf. I push it back to my garage and see that the starter fuse is blown so I replace that and it fires right up like normal. I shut it off after the quick test and put my tools away. I go to start it up again and now it just turns over and doesn't start. The fuel pump primes, battery is good, bank sensor is upright, but it just turns over now and doesn't fire up at all. Any suggestions?
Old May 6, 2017 | 10:01 PM
74demon's Avatar
Try holding the throttle wide open and crank it.
if it starts, close the throttle.
Old May 7, 2017 | 06:35 PM
I tried hold it open didn't work, maybe the voltage regulator is bad?
Old May 8, 2017 | 11:23 AM
74demon's Avatar
doubtful. The regulator doesn't do anything until the bike is running.
When you did get it started, how was it running?
Old May 8, 2017 | 04:50 PM
It was only on for a few seconds and sounded fine when I got it started again. I put a new voltage regulator on today because I had someone tell me that could be it and it was only $15 and that still didn't fix the problem
pacemaker
Aug 3, 2019 09:35 AM
psalas3
F2 Tech
Jun 22, 2015 11:45 AM
toaliosis
Jul 30, 2008 07:28 PM
