'02 CBR F4i
on
1 Post
yep.. as said before there is no difference in the side for the bar ends... more than likely the bar end is not sitting correctly in the other part (located inside the clip on). The only other thing I can think of is that the grip on that side might be shorter than the other.. but that would be weird...
+1 the same thing happened with my older bike...i would start by checking the bar end was seated properly if so then check the handle bar weight...on my older bike (not sure if it's the proper way but i just tapped it in with a hammer.. i didn't hit it real hard just taped it in...but from the above i would go that route...lol...
