01 F4i questions
F4i's are built like friggin tanks.... no worries
Biggest problem with the F4i's (and Hondas in general) are CCT's and regulator/rectifiers. But you can replace the CCT with an APE manual to fix that for good, and then the regulator I dunno sometimes aftermarket ones are a lil better than OEM... but FWIW my original did last 100k miles
My '04 F4i just turned 146,000 miles tonight, and still running like brand new. Only major problem was a trans problem (jumping out of 3rd gear) that started at 114k miles. Ended up having to replace 2nd, 3rd, and 6th gears and the shift forks. I did it myself though so no biggie. Other than that just a couple little things, nothing of much significance. Bike has never once let me down or left me stranded anywhere!!
I say go for it..... F4i is a great bike, you won't be disappointed!
I'd like to see a picture of the 146K mile odometer, if you don't mind. Not that I doubt, but that I want to make sure mine will go up that high. :-P
Regarding reliability and issues, my issues have been corroded electrical connectors, but I wouldn't say that's a common problem; the previous owner most likely let it live outside. If you're worried, fill the connectors with dielectric grease. Other issues I've had are the Cam Chain Tensioner (APE fixed that), and a faulty speed sensor, which generally happens around 15K- 18K miles. Beyond that, I haven't seen or heard of any major stuff that's common across the board.
The odometer would only show 46,000 miles. It rolls to all zeros at 100,000.
http://www.youtube.com/watch?v=RwiOy...eature=related
