'01 F4i - no start
Old Feb 22, 2017 | 09:00 PM
Pick A Username's Avatar
Default '01 F4i - no start
I'm going to look at an '01 F4i with 15k miles on it.
Supposedly sat for almost 2 years...
Will not start, cranks over with a jump but nothing more than that.
I guess I'm just looking for the simplified list of culprits as the search function doesn't work on my phone...
Battery, stator, regulator/rectifier...
Lack of compression...
Plugs/coils...
Anything I'm seemingly missing or any easy attempts to start it other than push starting?
Not sure if it's worth physically pulling and checking plugs as a first step (if I buy it).
Feel free to spam me with...
"Use the search function you poo poo head!"...
Thanks.
Old Feb 23, 2017 | 08:08 AM
Additionally, any idea on current day value (in NY) or your area of a non starting f4i?
Plastic repainted, someone put a 12 o clock bar on for wheelies...
Someone hacked in some LEDs, probably a 6.5-7/10 condition wise other than not running.
Old Feb 23, 2017 | 01:32 PM
cornflakesk's Avatar
when you turn the key does the fuel pump prime?
Old Feb 23, 2017 | 02:05 PM
Owner stated that it does prime, and there is no flashing light series for codes.
Old Feb 23, 2017 | 04:50 PM
boredandstroked's Avatar
If the gas is two years old that could be a problem. Otherwise you gotta make sure it has fuel, spark and compression. Reg/Rec won't be causing it that I know of. Push starting won't help it any more then cranking with the jumper. Not alot from the factory that goes bad to cause this stuff but combine stunter parts with "hacked" led's and I'd be worried.
Old Feb 23, 2017 | 06:57 PM
put the key in and listen to the tank if u hear a growling sound then its priming....if its not u cud have a bad sensor and the computer is cutting fuel and spark
HenryF
May 26, 2012 01:18 PM
Slim@SBF
Dec 9, 2007 08:53 AM
cbr714
Jun 10, 2007 07:55 AM
ThisisMickey
Dec 7, 2006 08:36 PM
atrious333
Jul 23, 2006 03:13 AM
