01 F4I Indicator lights & won't start
ORIGINAL: lxi226
01 F4I rode for ~1 hr set for 10 min then turned on the key, put on my helmet went to start it and noticed the turn and high beam indicator lights were on as well. started for ~1sec and shut itself off keeps doing this. Won't start....anybody no what's going on????
Thanks in advance
Thanks in advance
edit: my buddy sent mea link to this website:
http://www.vlc.com.au/~justin/about/...g_replace.html
I'll mess with that if the kickstand switch idea doesn't work.
Looks like pin or harness problem.
Just got home and pulled the fuses. It took 3 (the h/light, turn/stop and Ind/meter) fusesbefore the fuel pump wound up.
Started right up and after a minute was able to put back in the turn/stop and Ind/meter but putting in the h/light just killed it. Putting on the turn signal also killed it.
Getting ready to pull the fairings off now. Have no idea where the headlight relay orupper sub-harness/forward harness are but sure I'll find it.
Anyone recommend a good shop manual or equivalent...better yet free web sites with tech details?
thanks in advance.
thanks in advance.
ok, its on the front of the bike, you have to check the green wire... That's what others did. Try cleaning the green wire on the connection between the main harness and front sub harness... The only thing you have to remove to fix the problem is your upper fairing, the headlight fuse (if you have to replace it) is on the little box on the right (if your sitting on the bike).
If you look at the connection between the two harness you will see the pin is corroded.
This should be a sticky, It's a common problem on the F4i ... Seems to be only the 01-03 right now.
ORIGINAL: suicidal
Sweet, Thanks!! layman's terms! +1
suicidal/FLYOU
Fixed mine!!! Thanks very much. Sub harness pin and wire looked fine, same with the relay connections. Just unplugged them both and plugged them back in.
Found the thread and downloaded the manual.
Thanks again and great site!!!!!
Todd
Todd
