01 f4i fuel pump not priming
Old 04-01-2012, 01:07 PM
squidhead's Avatar
check the fuel relay under the seat on the right side of the bike. it is the one in the back. the first one is the starter relay, turn key on and kill switch on and you should hear a click in the relay. if not the relay is bad. you can use your headlight relay to confirm, they are the same. its by the bas between headlights. if that is not it spray carb cleaner in carbs and see if it pops to confirm spark. if no spark check the zener diod in the ignition. the pink wire, it needs to have between 8.5/9 volts on the out going side of the harness. if not bike thinks it is being stolen and spark and fuel are shut down by the ecu. good luck that is my problem.
Old 04-02-2012, 01:14 PM
dveldtf4i's Avatar
Originally Posted by jworkman78
Alrighty. I will let you know. I checked the fuses (they are located under the main seat correct)? Yeah i never thought of a short. ill have to look for that. but would a short cause the fuel pump and the spark plugs to not get power?
The short that I had caused my headlights not to come on, and my fuel pump to not prime. The two are linked together somehow. Are you sure your bulbs are burnt out? If the pump is priming when it's connected directly, then there's something else between the battery and the pump that's causing the problem.
Old 04-06-2012, 07:00 PM
squidhead's Avatar
did you ever get to the problem??????? i put in the new/used ecu today and still nothing. i am really getting sick of this thing. let me know if you had any progress please. i still have no fuel pump and no spark just like you.
Old 04-08-2012, 07:01 PM
jworkman78's Avatar
Registered Users
So I tested the fuel cut off relay today and hooked it up directly to the battery. It clicked, however I have a multi meter connected to the wires going out and no power. So it's like the power is going into the relay and not going out even though it clicks. I'm guessing that means it is bad?
Old 04-10-2012, 05:23 PM
jworkman78's Avatar
Registered Users
ok so i got the bike running! it was a bad ground in one of the electrical connectors. impossible to find unless you have a multimeter.
Old 04-11-2012, 11:07 AM
dveldtf4i's Avatar
Told you it was probably a short =P Glad you got her running, electrical gremlins are the worst. Pretty sure mine was the same issue, but I never nailed it down to which connector was the problem.
Old 04-11-2012, 04:32 PM
jworkman78's Avatar
Registered Users
yeah it was a pain. i guess on a positive not i know my bike a lot better now! thanks for the help!
Aj Getitin
04-12-2014 11:18 AM
whatthekrapp
06-17-2013 11:12 PM
mnazary
03-21-2012 07:44 PM
my750
03-15-2012 09:14 PM
iRIDE_F4i
05-01-2011 11:09 PM
Quick Reply: 01 f4i fuel pump not priming
