'01 f4 overheating
Old 06-16-2005, 09:29 PM
ItalianBoy425's Avatar
Default '01 f4 overheating
i just bought my bike 2 weeks ago. first bike so i dont know alot about bikes. the temps gone up to 230 a few times while sitting in traffic. is this normal??any suggestions.
Old 06-16-2005, 09:45 PM
Saruji's Avatar
Default RE: '01 f4 overheating
You know what i'm cruizing these forums to find out that exact same question, when my bike reaches 225 though the fan turns on and keeps it there longer, however it will eventually see 228, at max 230, this only happens in the city at longer red lights. I have no idea what an operating engine should operate at and where in the engine is the sensor placed? as in where is it detecting this heat? I live in Utah, its high up and dry and hot. Could someone please shed some light on this. I dont own the repairs manual yet, but I think it would be in there.
Saruji.
edit i have a 2002 f4i with an arrow titanium exhaust, power commander and basicly a direct intake without much of a filter, I imagine this gives more power but also creates more heat, dunno, when I go cruizing through the twisties it sits a 180.
Old 06-18-2005, 11:37 PM
majin ssj eric's Avatar
230 is normal. The bike will let you know if it is running hot (ie, the temp light will come on).
Old 06-19-2005, 02:01 AM
The worning lite will come on when the bike heats up to 260.
Old 06-19-2005, 01:14 PM
Try putting your air filter back in. But I think your bike will be fine
Old 06-20-2005, 11:48 AM
I live in L.A., so it doesn't get to terribly hot here, therefore my '01 f4i only sees about 230! & that is in heavy traffic...
Old 06-20-2005, 05:12 PM
i use redline water wetter, and a less than 50/50 antifreeze/water solution. it helps the bikes ability to stay cool at slower speeds but sitting still is a real killer for these little fours.
x
Old 07-08-2005, 01:42 AM
Fox's Avatar
Fox
Fox is offline
Mine reached 229 or 228 once, that was in 95 degree, Boston heat, last month in bumper to bumper traffic. The radiator fan kicks in a few degrees before that, I believe 224. I wouldn't sweat it. If the idiot light on the dash stays on, that's when you have a problem. Doesn't sound like its overheating to me.
Old 07-09-2005, 01:19 PM
Dude its ok. 230 is nothing, my bike gets to 235 all the time at stoplights in summertime, then you get goin and it drops to 180 or so. Worry when it hits 255-260, which it probably wont.
Old 07-09-2005, 02:29 PM
id check your fan fuse under your driver seat just make sure the fan is working so you dont see any higher temps
Quick Reply: '01 f4 overheating
