01 CBRF4i - Taking cage off
Old 11-27-2017, 11:45 AM
Default 01 CBRF4i - Taking cage off
Hey guys,
New to the forum here. I bought a F4i a year and a half ago, and not long after that it got stolen. I've been working on it on/off during the past year. Long story short, I'm trying to do some maintenance on it, but keep running into the Sick Innovation cage that the previous owner installed.
I've been trying to take it off, even reading how to install it and try to do the reverse order, but no luck. I bought the replacement parts (I think) to take it off. I have 3 engine bolts, and the R/L engine mounts. Is that all I need to take off the cage? I'm also having a hard time with taking off the bolts since the bolt-head is rusted and either rounded off or I don't have the right bit.
Any help is appreciated!
TL;DR - Need guidance on taking off cage, and parts necessary so the engine doesn't fall through.
Old 11-27-2017, 12:23 PM
CaBaRet's Avatar
Tell you the truth matey, never seen one, but then again I'm old
Old 11-30-2017, 10:37 AM
Its just removing the bolts and replacing with stock ones that don't hold on the cage. Same thing as doing frame sliders pretty much. Put a jack under the engine to hold it. I'm not sure how much help we can be when you already have the instructions telling you how its done.....
Old 11-30-2017, 11:06 AM
Appreciate the responses. That does help, I was under the impression the engine wouldn't drop at all, but it seems like I would need a jack to hold it in place while I change out the bolts. I also thought I needed more parts, but it seems like it's as easy as just replacing the bolts that hold the cage in.
Old 12-01-2017, 02:37 PM
If you were doing 1 bolt at a time you wouldn't need the jack, but you need to do multiple at once which is why I suggest it.
Old 12-01-2017, 03:33 PM
Hawkwind2016's Avatar
If the bolts are rounded, then something like this will do the job :-
https://www.ebay.co.uk/itm/VOCHE-10P...gAAOSwevdaAvjZ
You need to find one that's a pretty close fit, give it a few taps with a hammer to get it on there properly and then you can get a socket on there to remove the bolts. Once they're off you can drift them out with a punch or something similar. They'll chew the bolts up a bit, but as you're not re-using them, it doesn't matter.
Old 01-27-2018, 06:12 PM
Are you looking to sell the cage by any chance?
Tall Boss
02-06-2010 10:12 PM
6hundred_doubleR
03-09-2006 10:26 AM
WhiteTailCBR
06-27-2005 08:46 PM
Quick Reply: 01 CBRF4i - Taking cage off
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
