Wheel bearings
How hard is it to swap out. The front wheel bearing? I was told by the shop when they put on a new front tire that my bearing was bad and they suggested that next time I get a new tire they will replace it... Well f them I hate when shops touch my bike so ima just do it myself. I found the bearings and seals for like 20 bones so I'm going to go ahead and place the order for that and a new oil pan gasket just to replace that as well.
I just did mine front and rear and I used a socket extension to tap them out from the inside. Then I used a socket the same size as the outer race to tap them in. That's how the clymers manual says to do it if you don't have the tools.
Some will say you need specialized tools for everything but if you listen to most forum people, you'll have $10,000 in tools you rarely use. |
Tap them out chasing around the race from the back-side. I use a 1/4"x6" drift.
To re-install the new (roller!) bearings, I use a piece of 1/2" all-thread and some big washers and 2 nuts. Gently start the bearing and then insert the all-thread thru the bearing with one washer/nut attached, pass it thru the hub, add the second washer/nut and start cranking. Only do ONE side at a time! Some things shouldn't be short-cut. This is a cheap/easy way to install any bearing that you can access, through and through. The socket method will work, IF you are very careful to drive the bearing squarely into it's seat. If you get it even a little offset, you will potentially damage both the seat and the bearings outer-race. So be very careful, if you go that route. Ern |
Sounds good thanks guya
Originally Posted by MadHattr059
(Post 1176696)
If it's working, you did fine. I just wanted to point out the potential issue, so others are
aware and able to compensate (before any damage is done), if using such a method. Ern |
That's a good one Ern. Surprised I didn't think of that. Damned early onset Alzheimer's! I Tapped mine in and noticed, on the front one, that it was a little difficult to put the axle in. After I finally got them in and tightened things all up they were fine. I felt them seat. Just last night I had the front wheel off to put the fender on and the axle went right back in. That tells me that everything's ok.
| All times are GMT -5. The time now is 04:42 AM. |
