Very odd electrical issues.
So I thought my R/R was bad. Bought the suggested GSXR one and wired it up tonight.
Had like 12.6V at the battery at idle and 13+ while revving but with a good battery the lights were still bright and dim with the throttle. Went to wally world and bought a new NeverStart. Put it in (did not trickle charge it) and bike fired right up. Tried to take it for a ride. Things got weirder. If I put the kickstand down, it would just flat stall. I pulled the clutch in THEN put the kickstand down and it was fine; is that normal? Out of my 7 bikes, none do this? So finally got that squared away and went for a ride. I think my petcock is bad so I Have a vacuum line hooked up to it; give it a suck and start it up and the bike runs fine :icon_screwy::icon_screwy: But when I tried taking it for a second rip up the street, and gave it some throttle and the lights went whacky and the temp gauge pegged :icon_emm: So I shut it off and let it idle again and all was fine. Put some vacuum to the petcock and took it for a ride. I've got the battery on the trickle charger and will hook up the vacuum tomorrow and see what happens. Anything else I should check? Sorry for the long winded post! |
Electrical gremlins can sometimes be traced down to a loose ground connection somewhere on the frame.
| All times are GMT -5. The time now is 08:46 AM. |
