Valve knocking?
Old Jun 14, 2012 | 04:42 PM
JankCibberf2's Avatar
Default Valve knocking?
I believe its what i have. Its super loud and annoying it almost sounds like someone put a bolt inside my motor just ratteling around in their. The thing is i replaced the pistons and rings and got the stupid thing honed out so it has perfect compression. Used my old head and replaced the head gasket and finally started it up, at first it sounded pretty good no knocking then after she warmed up it sounded painfully loud. Do i have a bent valve, or stuck lifter? also do i need to drop the motor for a 6th time to pull the head?
Old Jun 15, 2012 | 05:00 AM
Also heres a video of it, could it possibly be that i literally dropped a nut down there?
[youtube]http://www.youtube.com/watch?v=NfswZrwdSQA&feature=plcp[/youtube]
Old Jun 15, 2012 | 06:57 AM
underground-mpyre's Avatar
Yep, a valve slapping. You will have to pull the heads and replace that valve or valves, more than likely bent. Seems somehow you timing is off or cam chain jumped a tooth.
Old Jun 15, 2012 | 09:06 AM
haha i knew i should have used the other head erghhhh
Old Jun 15, 2012 | 11:07 AM
wagzhp's Avatar
Check your pistons when you have the head off. With that much noise I'd be surprised if you didn't damage one of them.
Old Jun 15, 2012 | 02:53 PM
From being started for that long?
Old Jun 15, 2012 | 10:33 PM
wagzhp's Avatar
I don't know, but that was some ugly noise... Hopefully not, but I'd sure take a look.
Old Jun 16, 2012 | 03:13 AM
Update my friends
Retimed it and the bike ran better and the noise was quieter, im going to swap heads tomorrow. however when i took out plug one it looked like the piston had struck it since it was shut. But then further inspection it looks like something actually hit it from the side like a bent valve that was stuck open.
Old Jun 17, 2012 | 03:24 PM
Default Picture update lolz
Old Jun 18, 2012 | 01:11 PM
Originally Posted by JankCibberf2
Wow, sorry. Looks like you are dead in the water. Those valves obviously did a number on that piston.
