Vac/Fuel Issue-Bogging Down, then Running Rich
I have also been through the tranny on these bikes... and I donno what to say about your 1st gear sticking after a drop. Are you sure you didn't just notice how easy it rolled when it was warm before? The cold stick mentioned above is very real. I have a dirt bike, a quad and this streetbike, plus many more wet clutch items in the family, and ALL of them do it. Very normal. The metal plates get stuck to the cork frictions plates when they sit there compressed to each other in a bath of oil. You know how if your cold glass of water condensates on a hard table how it kinda suction-cups itself to the table just because of the water? It's like that. Kinda...
There's not really much that can move in there. If you're sitting there in 1st with the motor running at a stoplight or whatever, do you feel the engine dragging the bike forward or anything? Depending on mileage and history, I'd tend to guess bad/grooved clutch basket fingers or bent plates. But... neither of those are really possible from a "drop." Unless... by "drop"... You meant ridiculous crash.
I couldn't tell you. I haven't had the bike on in about a week or 2. I've been trying to fix every possible thing that I can, and every time I fix one thing, something new pop's up. I got the clutch issue resolved. Turns out that the elbow that holds the clutch cable on the housing was bent, so, I replaced that, and it's all good now.
Cant just weld it back on? This was a common problem on the ex-500 forum and the fix was to just weld it back on.
http://www.lincolnelectric.com/knowl...ronpreheat.asp
https://cbrforum.com/forum/showthrea...t=94895&page=2
Im going to attempt welding it if the journal behind my starter gear is bad. I already have a new cover on the way.
