Stator cover problems and woes
Hey everyone. I had my stator cover off to make sure everything was looking okay in there. Now that I'm trying to get the cover back on I'm running into some problems. The starter idle gear had some play in it. after trying probably twenty or thirty times to get the cover to fit I figured this was the cause of the problems. I tried moving the flywheel bolt a little to see if I could get it where it should be, and now the starter idle gear is just messed up and not where it should be. The little pin that goes between that and the cover just slides right through. After looking at the service manual it says I need a flywheel holder to take that bolt off (and I assume I need to get the flywheel bolt off to get the starter idle gear back where it should be?) Is there any more commonly available tool that will let me get the flywheel off? Any other suggestions for dealing with this thing?
Also, is a new gasket absolutely necessary? Or will a nice coat of rtv do the same thing?
